Mickeytex
Project Manager
Hey, new to the boards thought I'd ask a question. Here is my situation. Working on putting in some wood floors in a half bath. As part of this process I am replacing the toilet and putting in a pedestal sink. It's just a half bath so not concerned about water with the wood floor.
Since i have the toilet off I noticed there is something interesting with the flange. Looks like there was 2 flanges. An offset cast iron (or brass) flange underneath an oatey twist-n-set. The rough-in was 12" from the back wall and about 10" from the side (right in pic) wall.
Pic:
The house was built in 1980 and since this is 1st floor in Texas, the flange is in a slab. So my dilemma is several fold...1) the old off-set flange stuck out from underneath the base of the toilet. Since the toilet was installed on the twist and set which was centered over the down pipe. Not the look i am going for with a new floor and bathroom. 2) using the twist-n-set, puts the toilet very close to the side wall. There is plenty of room in the bathroom so it's not apealling to have the toilet up against the wall. 3) if i took the twist-n-set off, I could use the offset flange...right...well the offset flange doesn't have the provisions for closet bolts on the "right side"...just top, bottom and left.
more pics:
So I am here asking you for options on what to do. What are my options? Should I:
a) remove the cast-iron flange, put a new twist-n-set in and live with the toilet close to the side wall?
b) remove the cast-iron off-set flange and put on a new off-set flange with a full install ring to mount a toilet?
c) other?
appreciate any advice....
Eric in Austin
Pic:
more pics:
c) other?
Eric in Austin
