Xroad
- Messages
- 113
- Reaction score
- 0
- Points
- 0
Hi Folks,
I removed the fan sub assembley from the bathroom exhaust fan unit. The mator was squealing. Easier to take the sub assembly down and replace the motor than removing and replacing the whole fan unit, which is attached to the ceiling. So, where do I begin? Who sells fan motors? The fan unit is Broan. The fan sub assembly said Nautilus. The spec on the motor + fan is stamped on the metal plate of the sub assembly: 120V, 115A, 60Hz, 70cfm, 3 sones. The motor itself have UPPCO inc. stamped on the body. The motor have a 4 inch electrical cord with a AC plug that plugs into the main assembly outlet. The motor shaft have a spline end which the plastic fan is pressed into the spline shaft.
Thanks
xroad
Thanks
xroad
