dirty water after submersible pump replacement
jackofmosttrades
i just replaced submersible pump in my drilled well and now am having brown almost black water coming through taps. i was assuming that the water would be slightly dirty from the torque arrester (or whichever the term is) scraping the inside of the well walls but this is extreme.
I was just wondering what would be the best solution for this problem or is teh best solution to do nothing at all?
any info would be greatly appreciated.
Sit tight and wait at least a day. My experience has been that debris has been stirred-up. By pass any sediment filter.
You should have pumped it open discharge on the ground at the well head before hooking it up to the house.
bob...
bob...
thanx for the info bob i will remember that for next time. hopefully there won't be a next time but will definately remember that .
jp
Run a garden hose off your holding tank until the water clears up. Pulling the pump up and putting it back down the well knocked off a lot of loose material on the casing and the rock.
sammy
www.tylerwell-pump.com
thanx for the info sammy that would have had to of been my next step but thankfully i was going away for a couple days and i just let the system sit and when i turned the pump back on this morning monday (after having sat since friday morning it was clear as glass. (good glass not that smokey stuff lol)
thank you all for the kind help and i will definately be posting on here for any future endeavours that i have issues with.
thankyou again
jp
