russosborne
10-22-2008, 03:56 AM
Hi.
I have a water heater that is dripping from the temp/pressure valve. Probably 1 gallon a week. I read here about the newer heaters having problems and one concern is having a check valve in the water meter.
Now, some kickers. I am just a renter. In this city(Akron, Ohio) renters can't get water service, it has to stay in the name of the homeowner. So I don't know if they would even talk to me.
I think the landlord's son likely installed this water heater himself. He is an electician, but seems to be the one doing all the work here. There is no expansion tank installed. There is pvc from the t/p valve, but it only goes to about 6 inches above the basement floor, not to a drain or outside.
So far we are ok with the drip, now that I was able to determine it was coming from the t/p valve and not the tank itself. Ended up putting a bucket under the pipe, just have to remember to empty it before it gets too full. :(
I just want to try to determine what the cause of the drip is, to see if we have any real ammo to get the landlord to fix it. We did mention that it was leaking when we first moved in, the landlord didn't seem too concerned. The other option is to make sure to keep stuff off of the basement floor.
Thanks.
Russ
P.S.
Great forum, and I appreciate you guys letting diy'ers asking questions, as opposed to some other forums out there. Mainly the electrical one that I can only read since I am not an electrician, but they did give a link to this site. :D
Thanks.
Russ
P.S.
