Low Flow Toilet & Flushing
amateur
I just bought a place where all of the toilets were acting up. I tried to fix my first toilet and I think I did a pretty good job. I replaced all of the components in the tank as well as the supply line from the wall to the tank.
I tried to flush it after everything was done and I noticed that it doesn't flush the same as it did before. It seems like it flushes one and a half or two times by itself when I flush the toilet. I used the FluidMaster products from Home Depot (fill valve model number W43LS and flush valve model number 210). I'm guessing one or both of these are wrong (even though they look identical to the parts that I replaced) or possibly I need to set the water level or something like that.
Any help is greatly appreciated. Thanks!
You have installed a 3,5 gallon per flush flapper on a 1.6 GPF toilet...
Get the right flapper...
I''m no fan of those kits...
They are not universal as you have found out, and you probably replaced a lot more parts than you needed to!
