What is this thing? See picture please!
Chris Poco
My landlord came with a box of copper things. Some are labelled "Sioux Chief Mini-Rester", and a Google search brought me here. What an informative link it is. Thank you Terry!
The other copper thing is still a mystery. See the attached jpg picture.
What is this? And is there a similar write up for this here or anywhere else?
Thank you for any help!
Chris Poco
thing
It could be a refrigerant in line filter/dryer, or depending on what's in it, it could be some type of shock absorber, but it is not like any I have ever seen if that is the case.
looks like
looks like a sensor or probe
looking at the left end it appears to have a probe end on it...
something that went into a port on either a refirgeration system
or into a port on a commercial hot water heater
both would be in series with some sort of aquastat which is connected to that greener end...
is their a prize or something for the guy that guesses this right???
Picture with closer look at ends
Prize for the one who guesses right? How about the thing itself?
Problem is I won't know who made the "right" guess since I surely don't know what it is ;)
Further info: Both ends appear to be sealed, and when shaken, the inside of the bulb gives off sounds as if it contained beads, sand, or some such. Not loudly though, I have to really put my ear to it to hear.
Thanks Mark, Mike, and hj for your attempts so far!
See picture attached for more details on the ends.
I Think hj's Got It!
Congratulations hj ! I've checked Grrainger's web site and found the item #6X526 exactly as you said.
Dryer,Liquid Line
Heavy Duty Liquid Line Dryer, R 12 Capacity 1 Ton, R 22 Capacity 2 Tons, R 12 Water Capacity @ 125 Degrees F 84 Drops, @ 75 Degrees F 99 Drops, R 22 Water Capacity @ 125 Degrees F 75 Drops, @ 75 Degrees F 90 Drops, Connecting Tube Inlet ID 1/4 Inch, Connecting Tube Inlet OD 5/16 Inch, Connecting Tube Outlet ID 0.127, 0.130 Inches, Connecting Tube Outlet OD 7/32, 5/16 Inches, Shell Diameter 1 3/16 Inches, Overall Length 9 3/4 Inches
So, send me your mailing address and I'll ship this unit to you as your prize if you want it! Just let me know. Thank you everyone!
