View Full Version : crooked tub spout
tubandbath
10-18-2008, 11:00 PM
I installed a copper pipe for the tub spout. I screwed on the tub spout and there is a gap of 1/4" between the finished wall and the spout. How can I fix this? The bathroom is already finished just this is the problem.
Redwood
10-18-2008, 11:21 PM
Shorten the stubout 1/4"
kingsotall
10-19-2008, 06:33 AM
Since there is a male adapter sweated on you will now need to cut the pipe shorten it to a 1/4" less then what you have now while taking into consideration what a coupling will add. Have fun!
tubandbath
10-19-2008, 08:46 AM
There is a male adaptor on it already. You mean just to cut the pipe somewhere in the middle shorten it by 1/4" add a coupling and that's it.
Cant I just bend it someway?
the tub spout goes in and out. Never tightened it behind the wall.
10-19-2008, 08:47 AM
If we knew how the spout attached we might have a solution, but since there are several ways it could be done, and sometimes the solution is a different spout, we cannot tell you.
tubandbath
10-19-2008, 11:15 AM
the spout is screwed in. its an american standard spout (symphony). It screws in about 1/2". The rest is soldered. Is that what you mean when you asked how it is attached?
Redwood
10-19-2008, 12:29 PM
Yes, the copper pipe with the male adapter on the end of it.
You would unsolder the adapter, cut off 1/4", then sweat a new one on.
tubandbath
10-19-2008, 04:17 PM
I appreciate the help. I understand to cut off 1/4", but there is a gap between the wall and the spout ONLY on one side. So, I would think cutting it won't help, there will still be a gap.
Redwood
10-19-2008, 07:33 PM
Ahhhh...
Depending on how it is connected to the valve...
If it is connected with a threaded adapter you could tweak it square...
If it's sweated you will need access into the wall to get in there with a torch...
jadnashua
10-19-2008, 07:36 PM
Bending it probably isn't a good idea. Can you get to it from the back side? If that's an outside wall, it gets messier.
Redwood
10-19-2008, 08:29 PM
I was not saying to bend it!
I was saying if it was attached to the valve via a threaded connection that turning the connection to square it would be appropriate.
If its a sweat connection then its a torch job...
kingsotall
10-19-2008, 09:41 PM
I like your way better Redwood. We're trying to get rid of not add.
tubandbath
10-19-2008, 09:47 PM
This can only be a sweat job. The wall is finished, and I have no access to a back wall.
kingsotall
10-19-2008, 10:07 PM
The tub spout as its being tightened can pull the pipe a bit. Only a bit! If that's all you need then best of luck. If it has to be perfect then they make escutions that will cover any access you need to get in behind with a torch and tweak it straight. If it comes to that come back for more advice on how to tweak an already sweated pipe straight.
Redwood
10-19-2008, 11:24 PM
The back wall is finished drywall right?
tubandbath
10-20-2008, 07:21 AM
the backwall is 1/2" wonderboard
Redwood
10-20-2008, 07:57 AM
That would be your access point if needed.
tubandbath
10-20-2008, 09:32 AM
redwood, you mean i would have to take off the tiles and cut the wonderboard?
jadnashua
10-20-2008, 10:44 AM
What's on the other side of the wall? A closet, another room, the outside? If you can cut an access hole there, patching is much eaiser than messing with the tile. The alternative is make the hole through the tile bigger so you can work through there, then use a decorative plate, or retile it. Or, live with it.
