wrighto33
05-31-2005, 10:53 AM
Hey All,
I have a small problem. I'm installing a new pedestal sink and I have soldered on a pair of 1/4" turn brass shut offs onto 1/2" copper lines. When I soldered the valves on I left them open, but it took about a minute and a half to get the valve hot enough to melt the solder. Once the valves were cool, I closed them and turned on the water. The valves are now leaking from the stems, is it possible I damaged some gaskets during soldering? If so how can I avoid this or should I just but threaded valves instead? Any help would be appreciated.
Thanks
Thanks
