Hello,
I had a pump/well test performed about 1 month ago. All tested good, however, ever since I have had a terrible problem with rust/dirt in the water. The entire house is badly stained, showers, tubs, toilets, sinks. I have a water softner and an OMNI filter in the system. We have always used iron removing salt in the softner. Until this test was performed we never had a problem. I have flushed the boiler holding tank, pressure tank and run the water for over 4 hours the past couple days. The Omni filter element becomes completely filthy after only a few hours now, I have used 6 filters in the last 2 days and I have no other solutions. The water is so bad we can't use it for anything. We are living off bottled water and shwering at friends. The well and pump are only 4.5 years old. What caused this and what can I do about it?
Thanks - emt8948
Thanks - emt8948
