View Full Version : Rust around overflow hole in tub
lkrides
10-12-2008, 06:08 PM
Hi All, we have a rental property that has a steel tub that has been leaking when the tub is overfilled. I tried replacing the overflow gasket and that did not solve the problem. I noticed rust around the overflow opening so i cleaned it thoroughly with a wire wheel and scrapers. After cleaning I noticed a couple of pinholes in an area that the overflow gasket will not cover. What should i use to repair the pinholes? An epoxy like JB Weld and cover with fiberglass or porcelian repair kit? Photos attached of front and back view. Suggestions appreciated.
Lee
Redwood
10-12-2008, 06:24 PM
Time for a new tub...
That other stuff would just be slumlord repairs that would only postpone the inevitable....
jimbo
10-12-2008, 07:02 PM
I understand the realities of the rental market.
That tub is done for, but if I were the owner and wanted to get another year or two out of it, I would apply fiberglass patch to the back side, and goop the overflow gasket wity silicone.
You can try to cover the rust on the front side with touch up. But there is cancer here which almost surely will continue.
The tile above the tub, looks iffy as well. What substrate is the tile laid on? You are not far from a major redo of this bathroom.
lkrides
10-13-2008, 07:08 PM
Thanks for the replies. I understand that the tub will need to be replaced in the not so distant future. We are just looking to get through a year with the bath as it is so we can focus on replacing flooring and other improvements.
The tile is on cement backer. In the pic the bottom level looks terrible with the mold in the caulk. The rest of the tile looks good. I'll redo the caulk with silicone.
Should I be looking for porcelain touchup? I have only seen acrylic/gel coat.
Very much appreciated!
Lee
Southern Man
10-13-2008, 08:43 PM
When you pull the tub you'll have to redo the tile. The cement backer goes over a nailer strip on steel tubs.
lkrides
10-16-2008, 10:21 AM
Do you mean just the bottom couple of rows?
jadnashua
10-16-2008, 10:44 AM
It depends on how tight the opening really is how many rows you need to remove. You often end up tipping the tub in place, so the diagonal measurement is the critical length. The tile and backer often make the opening a fair amount shorter. A tub is often very close to the 60". Measure the inside opening between tile and it'll give you an idea how much room you've got to play with.
