Jakemembers
05-31-2005, 09:03 AM
I'm installing some irrigation line and want to put in some additional hose bibs off of the main irrig. line. I'm planning to use copper for the hose bibs for strength and already read that where my PVC main irrig. line converts to copper I should ensure that the female connection is copper and not the PVC. So thanks for that.
I was planning to add some additional support by putting a support leg between the 90 at the top of the riser out of the main and the hose bib by installing a tee and a section of pipe capped on the bottom that would also be buried. However, since the tee has a stop in it keeping me from feeding pipe straight through to the bib, water will fill this leg and just stand there. Will this cause me problems later? Are there any other suggestions for supporting the hose bib without it being next to a structure?
