Whats this green stuff on my copper pipe
penguin933
Its green on pipe with some white stuff (maybe paint). I moved into this apartment a year ago just noticed this.
When copper oxidizes it turns green. On pipes you usually see it where the moisture or humidity is highest. If you get some really bad joint work you'll see it heavy around the solder.
Didn't you watch Roger Rabbitt...? It's DEATH!!!!!!!!!
Actually it's just the copper oxidation.
why copper turn green
The green patina that you see on copper is the result of an oxidation process, that is corrosion. the patina is composed by copper oxides and carbonate, it's a spontaneous process and it occur whne copper is exposed to the atmosphere.
why does copper turn green
copper pipe corrosion
hope this help
Vittorio
