I am re-doing the framing and subfloor of a small powder room in my house. The toilet flange is 11-1/2 from the finished wall to centre of flange. The spot where the toilet has to sit is boxed in quite narrow on one side, with a heating duct. It is 11 inches from one side and 12 from the other, to the centre of the flange.
I can lever the flange over towards the middle. It is at the end of a ~4 foot run of 3-inch copper and I just successfully levered the flange up to the new required floor height (about an inch higher than before) and heated up the nearest sweat joint to let it relax in that position. I could move it closer to the centre by 1/2 inch that way as well, if needed.
Having changed the angle of the pipe by a smidge, the flange itself is now not quite level. When the time comes, I think I will be able to heat up the flange to let the solder flow and adjust the level a little that way. Will that work? Is there enough play in the 3-inch sweat flange?
Aside from this being too narrow a place by far for a toilet, can anyone comment if a Toto Drake will fit in this narrow an opening? The old toilet that came out was not particularly narrow, so I can't imagine a serious problem with a modern one, but I reckon better safe than have to take back a Drake that doesn't fit after all.
Thanks
Thanks
