View Full Version : Need advice for bathtub leak
Yong 9630
09-29-2008, 07:39 PM
:confused:I have a leak coming from somewhere under my bathtub. I have one of those fiberglass tub/shower combos. I used some Liquid Plumber to try to unclog the drain and I forgot to go back and run hot water through the drain. The next morning I had water leaking from under the tub in the bathroom floor. What is my most probable cause for the leak? Also I have removed the drain in an effort to access the rubber seal, but the seal is under the tub, not the drain, so what would be my next step?
kingsotall
09-29-2008, 07:46 PM
Best next step is to consider investing in a plumber to remedy this problem.
Yong 9630
09-29-2008, 07:52 PM
Have been trying to avoid expensive plumbing charges, but there is no access to the pipes beyond the drain with this fiberglass tub/shower combo. Do not want to tear apart the bathroom to get to the pipes, is there any other solution?:(
patrick88
09-29-2008, 09:00 PM
That would be your next best solution.
jadnashua
09-30-2008, 05:35 PM
The chemicals might have disolved the old metal trap. You may have to poke a hole in the ceiling below to see what's going on. If you cut carefully, patching isn't too bad. You'd probably take more care than a plumber would when dealing with the ceiling.
psolutions
09-30-2008, 05:39 PM
Your best bet is to call a plumber.. We arent that bad, i promise!
