AndyDavis
- Messages
- 8
- Reaction score
- 0
- Points
- 0
We just completed a significant remodeling job. Part of the job involved the installation of a new 4" branch drain line which was connected to the main line.
If it matters, the branch line services two toilets and a shower. The house is a slab foundation.
The real issue seems to be how the branch line was connected to the main line. The plumber wasn't able to get a proper coupling around the lead pipe, so he jammed a piece of PVC as far as he could and then used silicon to hold the PVC in place. He then made normal PVC to PVC connections for everything else.
We have had a different plumber in helping us clear a a clog on this line (the original contractors left a rag in the line), they ran a camera down the line and discovered the silicone.
According to them, this job is a great sin in the plumbing code and will always cause problems. I don't really doubt the first part, this was obviously a hack solution. I want to be sure about the second part. If it is going to cause problems, then I will go to the original contractor and insist that this is repaired (and that they pay). However, if this is a hack that isn't going to really be an issue, then I can live with it as well.
The estimate for the repair is just over $3K, the original job was just shy of $10K. Getting them to pay up may require litigation, and I'd rather not go there.
The new estimate is for breaking away the concrete, removing the lead pipe, and connecting the 4" PVC to the cast iron main drain with proper couplings. It also includes an Engineers Report (needed for some work that affects the slab).
Any advice would be greatly appreciated.
