Hey all.
Might seem kinda weird. But I need some advice from people who know about using brass as your bonding metal on 1/2 copper pipe and aircraft aluminium. Possibly as well with fine gauge steel meshing.
You see several years ago I twisted and glued myself up a ferret backpack cage from an old army backpack frame. It's aircraft aluminium. Chopped it down to size. Cut copper pipe and made a framework emerge from the base I made. Once wrapped in tiny gauge .5cm spaced steel meshing; Kinda ends up looking like a ferret hiking cage.
My experience level was quite low, and at the time I thought it best to stick with glue and zipties. Mind you it still looks very professional I must say. Over the years I've made better repairs, and started using rivets and metal sewing Thus abandoning the zipties formerly anchoring the mesh.
Now I want to clean it all up, solder it all together again with brass. Then my NEW concern is soldering brass into the sewn caging on the framework.
Any suggestions.
Any suggestions.
