View Full Version : Moving and changing shower valve help
zoomzoom3
09-17-2008, 08:08 PM
I went from a 34" X 48" pan to a smaller 32" X 48" pan. By doing this I just realized that my shower handles are way off now. I also was planning on switching from a two handle to a single handle moen valve.
(The left handle is actually where the center of the shower/valve should be)
1) How would I move the supply lines and valve to work with the new pan.
2) Can I just use two 45 degree fittings to move the left supply line to the left about 4-6" and then just leave the right supply line alone.
3) Does it matter how high I start the 45's.
Any other suggestions.
Thanks in advance,
dan
5411
patrick88
09-17-2008, 08:58 PM
the wall looks to be wide open. I would do what ever it takes to put the valve were you want it to be. You have the choice to place fittings anyplace you like.
good luck
Redwood
09-17-2008, 09:44 PM
I would replace that valve while the wall is open with a pressure balanced mixer.
09-19-2008, 07:58 AM
IF you use the correct valve its openings will be on the sides, not the bottom so you can run the lines anyway necessary to get them into the proper position.
