sarahw97
09-17-2008, 12:55 PM
OK so I installed new Kohler pedestal sink. Fine. Installed Pegasus faucets. Fine.
Only remaining hitch is that the lever pull for the plug isn't working, because it seems that the distance between the waste/ball valve ("horizontal stick") and the pull-up ("vertical stick") is too great when mounted to this sink, therefore the plastic part with the holes / spring clip arrangement does not reach without being bent, and if it's bent that much the spring clip flies off..
Is there such a thing as a longer "horizontal stick"? or is there another solution?
If so, what's it called and where do I get one? Thank you!
