newowner123
09-16-2008, 11:26 PM
20 year old house. I am the 2nd owner. Bought the house in May 2008.
There is a Cash-Acme EB-86 PRV just behind a gate-valve house shutoff-valve. Both PRV and gate-valve look original.
I used a $10 Orbit water pressure gauge from Home Depot and measured pressure on the garden hose bib, which I believe is regulated since the pipe came out of the house and is apparently controlled by the house gate-valve.
Ok here are the observation:
1) Static water pressure varies from 90 - 110 psi, depending on the time of the day. I adjusted the screw on the PRV but it did not make any difference.
2) When a faucet is opened, water rush out, then after five to six seconds, water flow is noticeably reduced, but still at a usable rate. When PRV is adjusted counter-clockwise, water still rush out, but the flow rate after five seconds is reduced, compared with before adjustment.
3) I am not able to find any water expansion tank in the house. I have not measured the hot water pressure yet as I don't know where to attach the gauge. Hot water from faucet behaves pretty much the same as cold water: water rush out then flow slows after five seconds.
4) After a faucet is turned off, I can still hear water flowing in the pipe for four or five seconds before it stops. The sound is especially noticeable in the garage where the PRV and house shutoff valve are located.
From what I read here and elsewhere, it seems that I should keep the static water pressure to at or slightly below 80 psi. So here are the questions:
1) Is my PRV broken?
2) Do I need a water expansion tank?
3) Where was the water flowing to after I turned off faucet? (This question puzzles me a great deal.)
Thank you so much.
newowner123
Thank you so much.
newowner123
