View Full Version : Tension In Copper Tubing
oreyes
09-15-2008, 05:14 PM
Help....
I'm a homeowner who soldered my first pipes just a couple of weeks ago. I recently converted from a shower-tub to shower only. To get the proper depth for my shower valve I have to push them into the wall about 1/2" and am concerned this tension may weaken the joints over time. The whole assembly is tight (not slack) due to my having to force them into place My lines come from the floor at 3/4 and I have a reducer to 1/2" one line come in at the front of the 2x4 on the floor and the other one towards the back of the wall and they both continue on to the 2nd fl shower through the ceiling. Do I need a do over and any suggestions? My wall is still open. Any help greatly appreciated.
Dunbar Plumbing
09-15-2008, 05:26 PM
Take video of what you're describing. If it is minimal movement, you should be alright.
Anything more and you need to make adjustments to not strain the piping into position.
Metallic pipe is far more forgiving than plastic in these terms.
Southern Man
09-15-2008, 07:37 PM
Wouldn't that be compression? I don't see how that could be a problem.
09-16-2008, 08:05 AM
1/2" should not create any problems. If there are any problems it might be that the movement tilted the valve so it is not vertical at the wall's surface.
Plumbworker
09-16-2008, 06:04 PM
why can't you offset the risers with 45's to get proper depth?
oreyes
09-21-2008, 10:52 AM
At this point only because its done. But I reckon if I was going to do over that would be it.
