Toto Aquia I not passing inpection?
Patchesj
I purchased 3 Toto Aquia I's for our new house. The plumber installed everything, but now we are failing our plumbing inspection and the plumber tells me the toilets aren't going to work. I'm not a plumber, and I'm not following exactly what is wrong. Basically he says they plug the sewer connection (septic in this case) and then flood the drains. They have this odd looking vacuum tube device they stick down the toilet to determine if the toilets are holding water properly in the trapway. Ours are not... He says he can remove the toilets, insert plugs, and the tests pass. Has anyone else run into this before? Could this be an installation issue?
Thanks
KY. It sounds like the concern is over the rubber seal between the bowl and the plastic trapway. The plumber and plumbing inspector say that is where it is leaking. (On all 3 units....). Inspector also added that he almost never sees these toilets pass and that they are not even on the approved fixture list.
This is what is failing.
If we can assume that the installation was properly done, then I agree with Redwood. This almost has to be a local or state code that has not been overhauled. The big question is, what can you do about it! Pretty hard to fight city (or state) hall. We can all agree that it's BS, but they have the hammer.
Well, I just found out that they are placing the inflatable plug in the PVC trapway (unifit) of the toilet, not removing the UniFit and placing the plug in the actual drain pipe. Toto rep seems to think this is the problem. The other thing I discovered (while watching a Bob Villa video of all things..) is that the rubber gasket in the unifit seals better when coated with plumber grease. Mine was not. So hopefully the combination of the 2 will lead to a passed inspection.
Now if you can just convince the local yokels that they don't know all they should, you may be home free.
Right... I'm thinking it might be easier to get Toto to send me an Aquia II.
test
Normally with that test they are checking the integrity of the entire system, and therefore they do not want the toilets, or anything, removed or modified from the way it will be when the house is put into service.
Update... The plumbers installed the toilets with plumbers grease on the rubber seals and made sur ethey were fully seating the toilet into the UniFit. Test passed! woohoo.
