GeoNOregon
09-14-2008, 03:56 PM
Hi All,
I'm stumped thought maybe somebody might have some suggestions. Been contracting, making boards shorter piles of scrap higher since Christ was a corporal, but my own damn toilet's making my head explode.
Here 'tis. Got an Am Std one piece, low vol toilet. Remodel bathroom in '98. Had shaky flang to floor connection and when I tore up the underlayment to replace it and vinyl, the ABs flange came loose from the waste pipe. I freaked at first, then realized it was a gift. I got a new flange, put new underlayment down and proceeded glue in the flange.
It was then I discovered the huge boulder under my bathroom. The drain pipe was hitting it, so the lowest I could get the flange was on top of the underlayment. It rested flush against the underlayment. I dry fit the toilet and checked the distance 'tween the toilet and the flange. Had enough for a 1/2 to 1 inch of wax, so figured I was OK. I laid the vinyl and installed the flange.
Put it all back together and everything worked fine. In fact, I had to push down pretty hard, as I remember to get the toilet flush against the floor - the ring was a big thick sucker with a plastic insert. Lotsa wax
A few months ago started getting some seepage. I finally got to it this AM. Figured I find a bad ring. It wasn't that bad of a leak. It would take a week or ten days to see any significant leakage. It wouldn't be a puddle as much as it'd get wet , then evaporate you'd see the 'stain' on the white vinyl.
I have been tryin gto figure out WHEN it leaked, it was more like use the toilet and later you might see the effect. Caught it wet very few times.
Was more concerned about the flooring and underlayment, so I tore it up instead of troubleshooting any longer. In almost 40 years of doing this stuff, I've never had my own toilet go bad, so I was feeling some guilt and anxiety about waiting too long. Usually by the time I got to other people's it was underlayment & even sub-floor. But it's hard to ask people how long they waited without them thinking you're saying, "hey fool, why'd you wait so long?"
Anyway, I was surprised to see the wax ring was in pretty good shape. The wax was well seated to the floor. It could have only been seeping above the ring, between the wax and the porcelein. But it didn't really show it. So I'm stumped.
Is the evidence of seepage above the ring subtle? What would I have seen? I'm gonna put it back together and wait to silicone it to the vinyl to make sure it's not seeping again.
One of the things about this toilet is it struggles flushing. It's like the first turn of the toilet is too sharp. So I have plunged the thing a lot, but usually all I have to do is give it a short quick up pull and away it goes. It's not really thrashing on it like I've seen done by others.
Is plunging too much really a way to mess up a ring? I read that and had never heard it before.
Anyone have imnput about the toilet, it's elf being flaky as far as not flushing correctly. This toilet was in the house when I bought it. DOn't know when it was put it. he woman I bought the house from was an organic gardener, and into conservation, etc so her being a quick accepter of low volume toilets wouldn't be surprising. Was there problems with the early Am Std toilets? This always seemed like a 'small' toilet to me.
I read a few minutes ago that some plumbers will use a second ring to add more wax. But as I remember I had a heck of a time getting it down far enough.
Any ideas, clues, hints or suggestions from those that have done more of these than me. All of the toilets I've installed have been new/remodel construction, I haven't done the leaky toilet, no damage work that would let a person see the subtle indications.
Thanks in advance. I look forward to hearing from you.
George
George
