View Full Version : Septic /leach field issues
boerdoc
09-11-2008, 11:14 AM
After 2.5 years we had our septic pumped. The pump co. said it was all the way up to the top. He recommended that we not seal the top for 10 days and see if the problem recurrs. Evidently my wife had been flushing baby wipes and there was a mat of them floating so he thought the problem would go away. If not they would jet the leach lines and add bacteria. (4 gallons or so). Well they did that and told us to check again in a couple weeks before closing the top tightly. Yesterday I noticed that the ground around the lid was wetb ut I did not lift the lid. I figure that the treatments done have not resolved the problem. Does this sound like a whole new leach field? If there is no place to move the leach field from the existing place do you have to remove the dirt and replace the dirt or just the lines? Finally, does anyone have any thought or experience with Infiltrator systems ?http://http://www.infiltratorsystems.com/index.asp
Finally, What kind of budget am I looking at for leach field replacement?
Thank you,
Kent
nhmaster
09-11-2008, 11:48 AM
because of size limitations I have the Piranah system and so far it's been working just fine.
Redwood
09-11-2008, 12:12 PM
Your link didn't work here it is corrected...
Sounds like he's softening the blow that is about to come...
Redwood slides the chips onto new septic system needed...
Better than even odds I figure...
The skinny is that there are a lot of things out there and many of them work very well. Your contractor will know what works good in your area and what the requirements are for a system in your area. Here they have very stringent requirements that must be met. Other areas are quite lax.
