15 Year old Draft Induced Furnace and Natural Draft gas water heater tied to B-vent chimney. All done by builder 15 years ago and inspected by county. Occasional backdraft which was caused by unsealed return air ducts in basement causing negative pressure. Sealed returns and backdraft appears to be gone.
So today, HVAC replaced with 95% high efficiency unit no longer using B-vent chimney. Pumber comes out to sub-contract Nat gas connection to furnace. Goes to re-light standing pilot of HW and say WOAH... Refuses to re-light as HW burner has about a 1 inch build-up of debris, combo of grey matter and rust like. Removes draft hood on top and sees same build-up on internal baffles. Leaves WH gas off and suggests chimney sweep to inspect B-vent. I understand he doesn't want to risk re-lighting pilot.
Plan on removing single-wall vent pipe between WH and B-vent and brushing out, cleaning, and inspecting. Then plan on cleaning out baffles from top and burner from bottom. Once clean I would think safe to relight and test for proper draft using smoke candles or equivalent.
At this point suspect backdrafting caused build-up. Opinions??
P.S. I have CO sensor in basement 5 feet from HW and one each floor all conneected together. Never had an alarm....
