View Full Version : Flapper Problem
Lowell
05-24-2005, 08:05 AM
I have problem with Flapper sticking in UP position. This started all of sudden without any adjustments being made to toilet tank (American Standard). I checked and both little tabs/prongs are in correct position. I have taken all the slack out of chain to handle and nothing seems to make any difference. Flapper is sticking in UP position when flushed and I can barely touch the handle and Flapper drops down and tank fills normally, otherwise water just continues to run.
The flapper will not stay up by itself, so you have to determine what it is sticking on, possibly the black float ball.
Lowell
05-24-2005, 05:07 PM
Thanks for your advice. However, there isn't any obstruction. No float ball since there is a fluidmaster fill valve installed. I don't understand it but the flapper does stick in the up position.
dc_homeplumber
05-24-2005, 06:33 PM
Though not terribly common, there could be calcium build-up on some part of the flapper or even on the flush valve tube that's causing the flapper to hang.
Considering that flappers are as inexpensive as they are, I would try replacing it. Unless you have one of the newer 3-inch+ flush valves, the red Fluidmaster flappers are great. There is even an adjustable one if you have a 1.5 gallon toilet. But also feel around and visually inspect for any blatent abnormalities.
Another possibility is that your flush lever is hanging in the "up" position, thus keeping the flapper open.
Lowell
05-27-2005, 09:44 PM
DC. Thanks for your help. Purchased Fluidmaster Red Flapper. Works great!
Mike Swearingen
05-28-2005, 05:07 AM
Flappers may look O.K., but when they stop functioning as intended, the rubber has gotten weak, and they just need to be replaced.
Mike
