Solder
buzzard
I have a full spool of solder that's been in the garage for I don't know how long.
it is Dutch Boy and has the following markings:
Sn 95% Sb 5% also says ASTM B-32.
I also have a half spool of one that is Oatey silver lead free solder but has no other markings.
I am soldering some copper for water supply lines and want to make sure this is applicable.
Soldered with No-Lead Solder
Just make sure that any solder that you do use doesn't say Pb on it which means lead.
The solder you're using is a combination of 95% tin and 5% antimony solders also bearing silver exist however the SB SN mix is the most common.
It is actually the other way around. Silver bearing solder is the most common. 95/5 is also available, but is not used as much as the regular stuff because it is less tolerant as far as heat is concerned.
