I have multiple threads here, but I figured I would rehash my problem to see if I am missing something.
About 4 to 6 weeks ago my hot water tank started leaking from the PVR - not a little leak, but a constant drizzle. If I turned any water on in the house the tank would stop leaking. The hot water tank is probably 15 years old.
My first thought was that it was a bad PVR, so I went to Home Depot and bought a new one. I installed it without any problems except that it didnt solve the leaking issue.
I then did some research and talked to several friends of mine and they mentioned a thermal expansion tank. I went and bought one and installed it but it didnt resolve the leaking PVR issue.
I have a water pressure gauge. If I let the water run for a little bit and then check the gauge, the pressure is roughly 60 PSI. If I leave the water off until the pressure relief valve starts leaking, it spikes upwards of 100 PSI. I also have a Pressure Regulator or whatever they are called.
The only thing I have not done to this point is call the water company, but im not sure they will be able to do anything.
What am I missing? I am not a plumber by any means (though I was pretty stoked to learn how to sweat my pipes) so any help is greatly appreciated.
T&P Valve looking at two sides.
