View Full Version : Shallow well sediment filter
Vic1226
08-13-2008, 12:51 PM
I draw water from Lake Champlain on a seasonal basis. The lake level is always changing so I'm moving the foot valve which sits on a shale bottom. When it gets shallow the waves kick up sediment that wears out the impeller. I have a window screen on the foot valve but I still have problems. I've looked at a filter close to the pump but it look fragile since the pump is sitting on the beach. Suggestions? Thanks.
Southern Man
08-13-2008, 02:04 PM
Can you put a pool filter on te suction end, just ahead of the pump?
Gary Slusser
08-13-2008, 04:33 PM
The best choice is a 'filter' on the foot valve and to keep the foot valve off the bottom slightly or more. Speedbump has one for submersible pumps and it might adapt for a foot valve.
IMO a filter on the suction line is not a good idea because the cartridges I'm aware of are made for pressure, not suction. And as it blocks up, your pump will suffer.
Bob NH
08-13-2008, 10:06 PM
The stuff that will wear out the impeller all comes from the bottom.
Put the foot valve on a float that will keep it off the bottom. Put the pump in the deepest possible water where wave action is minimized.
If you can put an old tank in the suction lines, substantially horizontal, with the inlet and outlet at opposite ends and the outlet higher than the inlet, that will cause the most severe sand to settle in the tank. You will eventually have to clear the sand out of the tank.
If you can put a large pipe, such as a piece of culvert pipe, in the lake and roughly seal the inlet pipe to the end nearest the shore, it will settle out anything that is large enough to damage the pump.
If you decide to use a filter you must connect it so the water flows from outside to inside. That is a "pressure" filter even though the pressure at the outlet is less than atmospheric pressure.
