View Full Version : outside shower
roughneck
05-19-2005, 04:51 AM
I'm building an outside shower and need some help with the plumbing. I would like to have hot & cold water shower , and also a hot & cold hose bibb.
Can any one explain the best way to go about this ??? Any help is greatly appreciated.
The only outside showers I've been able to locate are cold water only??
The shower will also need to be drained for the winter.
05-19-2005, 06:59 AM
How are you mounting the shower valve? If it is inside the wall you can use any shower valve. If it is outside, many companies make an exposed shower valve. You have to install the piping so it can be drained, but we cannot tell you how to do that without seeing your setup.
