jeffw41
08-11-2008, 03:09 PM
I recently had an ejector pump replaced 3 months ago. The other day I noticed the rubber coupling on the low end of the check valve developed a split/leak. I went to the local plumbing supply store for a replacement. the discharge pipe is 2"copper - the check valve is 2 inch copper. I was told I needed a 2" rubber coupling with worm clamps.
No problem attaching to the check valve but, evidently, 2" copper pipe is not the same O.D. as PVC. Now, in fact, I have tightened the coupling to the copper pipe. Even though there seemed to be quite a bit of slack - no leak. I am concerned that this will only last a while before the coupling splits again because of the slack take-up.
Is there a better way to make this connection? Is there a rubber sleeve I can put over the copper pipe to take up some of this slack?
