View Full Version : Pressure Balance Loop
dk4dk4
08-10-2008, 10:36 AM
I need to create a pressure balance loop. The diagrams I've seen show a 4 way tee to start the loop (supply line, then left, right, straight through the loop).
Does anyone know if that 4 way 1/2 copper coupler exists? I can't seem to find it? Or is there a special name?
__v_________v_____
4_________________
___v________v_____
The 4 is the 4 way copper coupler, and the rest is a crude loop! :)
Thanks in advance!!!
nhmaster
08-10-2008, 01:02 PM
Yep Revere copper has em, called a cross. You might get one at the local plumbing supply (not lowes or hd, a real plumbing supply house) you may have to special order it.
08-10-2008, 04:38 PM
Pressure balance loops are an exercise in futility. I never install them unless the heads are great distances apart, and then I run separate pipes from the valve to the two ends.
