View Full Version : Help I 've got the hot and cold reversed
Stryker58
07-26-2008, 02:33 PM
I have a shower that has a Mix-It shower control. It was leaking so I took it off and went to buy a new one. When I got it installed my wife took a shower and told me the hot and cold sides were switched now. I thought I put it in the way it came out , what can i do to reverse it? :confused:
jadnashua
07-26-2008, 04:08 PM
With some brands' cartridges, you can flip them 180-degrees to fix backwards supply lines. Do not know if yours is one of them. Apparantly, the one you took out was. It is also possible that your valve is installed upside down. Some are designed for a tub and when using it for a shower, you still use the bottom outlet, or move the plug to the other side.
I've read that this tends to happen with back-to-back installations...one of them will be backwards unless you do so fancy cross-overs with the supply piping.
You may need to swap things around.
07-27-2008, 07:13 AM
Mixet valves do not have a "hot and cold" side. You just flip/reverse the temperature lever handle to change hot and cold.
