Fred T
07-21-2008, 09:16 PM
Greetings,
My Climate Master thermostat on my Climate Master Geothermal Heat pump switches the reversing valve to heat mode every time the unit starts for heating. The reversing valve does not switch all summer. I had expected that when the thermostat is manually switched to heat, the reversing valve would stay put all winter, but that is not the case. I am thinking that the less cycles on parts, the longer they should last. Does every heat pump thermostat operate this way?
Thank much,
Fred T
Thank much,
Fred T
