View Full Version : Well stopped working
sandiego101
07-20-2008, 05:00 AM
About a month ago I had no pressure I tapped on the pressure switch and the pressure came back So I replaced the pressure switch. I then tried to adjust the low and high on the pressure switch and could only adjust the low side to 40 psi and the high side to 50 psi. so for the last couple of days the switch would come on a lot and to my horror. I woke up to no water. I tried putting the old pressure switch back on and no pressure all the breakers are fine. my guess would be that the sub-merged pump is dead. Not sure were to go from here. should the bladder on the tank have 0 PSI with 0 water pressure? any help would be great.
Thnks
