poly fittings
davidw
Hi,
I'm putting in a new pressure tank and for various reasons want to put it in a different location. I need to add about 15 feet of 1" poly to the supply line from the well. Questions: Is there a usage difference between the nylon and galvanized barbed unions and which would you recommend using? Is there a better way to join the pipe other than the barbed fitting? Thanks.
David
There is no other way. Barb fittings have to be used with Poly. I would go with the Galvanized not the Nylon.
bob...
Thanks for the replies. I hadn't thought of using PVC inserts. They would work with the Polyethylene? I agree with Gary on the galvanized. The plumbing on the old pressure tank is galvanized and is almost completely blocked after 14 years. But I didn't want to use nylon if they would compromise strength. The tank is in the crawl space, by the way.
If I do go with the barbed couplings, any tips for installing them? I've heard they (especially larger ones) can be a beast to get all the way in.
David
David
Apply modest heat to the pipe before inserting the fitting. Some suggest hot water, others use a heat gun or hair dryer, some use a torch with great care.
A hammer is often helpful when inserting the first end of the fitting into the pipe. If you can get a two-hand grip on it and push against something you can usually get them in.
The PVC insert fittings have quite a reduction in area that causes some loss of pressure, and they are usually molded with a sharp internal corner at the insert. I use them but I chamfer the inside of the fitting at the inlet end to smooth the flow. It doesn't take much to make a big difference in pressure loss at the fitting.
Thanks for all the responses. I finished the install last night. I decided to go with the nylon barb. Brass(bronz) would have been better than galvanized, but the local hardware store only had the nylon and galvanized. The first side I was able to muscle in by twisting and pushing, but the second was somewhat more difficult. I wasn't too thrilled about using a hair dryer while sitting in a puddle of water, so I carefully used a torch to warm the pipe. I was then able to get it in up to the last barb.
David
