View Full Version : Can't Remove Shower Drain -- Part of Shower Pan? (pics)
mbloom
07-11-2008, 03:08 PM
Is it possible that the drain was permenantly attached to the shower pan? I had a leak, spent two hours getting out the lead and oakem thinking I could replace with a rubber gasket. Local plumbing supply suggested repacing with PVC and using a rubber PVC to copper coupler. I can't figure out how to remove the old drain.
Appears to be one piece -- no threads or gaskets... House is 30 years old, unsure of shower.
Bottom (note joist appears in the way):
http://www.logicgrid.com/3528a.jpg
Top:
http://www.logicgrid.com/3532a.jpg
Redwood
07-11-2008, 04:40 PM
"Terminate with extreme prejudice!":eek:
Remember Apocalypse Now?
07-11-2008, 04:42 PM
That drain is "fixed" to the pan.
A rubber donut may work.
mbloom
07-11-2008, 06:12 PM
Thanks Terry, that is what I was afraid of. If I can't get the donut to work do I need to look for a 100 year old plumber who still uses lead and oakum?
pbradley_1
07-12-2008, 09:25 PM
It looks like you have a wedge-lok (sp?) drain. Thay are still sold. There is a dount gasket that goes between the flange and the pipe. Not sure why something else was in there. I just removed the one from my shower.
07-13-2008, 06:49 AM
It should be pressed together so if you cut a slit in the lower piece it should open up to allow you to pull the two pieces apart.
