K2
Hello,
This is my first post! Exciting stuff.
I'm installing a Takagi TH-1 (LP) water heater and I had a couple questions I'm hoping someone might have insight into:
How close does the T&P valve have to be to the water heater? The reason I ask is I've read in order to connect to PEX i need a 18" flex coming out of the hot water supply. Thoughts on how I can install the T&P valve in this scenario?
Also the T&P valve per Seattle code states the T&P valve has to drain by gravity and can't be longer than 30 feet..the takagi is mounted below ground level which would put the T&P valve below ground level (i.e. can't drain by gravity outside) and no floor drain in site
...Thoughts?
Thanks everyone, this is a great site, tons of good info!
Kurt
Kurt
