What to do?????
Chestnuts
DIY Member
We decided to remodel a back room of our house. It appears to been a room added to the back of the house years ago. We found the original siding beneath sheetrock. It has always been hot during th esummer and cold during the winter. WE found alot of gaps in the wood and siding. We also found some surprises. Like a live garter snake behind the sheetrock and a snake skeleton behind some insulation. The back door was the biggest surprise. Look how the locks where attached. You know 3" screws only work when they go into wood, not the sheetrock. Now I need some help as to how to fix this problem.
Statjunk
DIY Senior Member
I kind of agree with HJ. The answer is kind of obvious. You're going to need to fur out that wall. Likely on both sides of the door. I'm really surprised that the temperature change of that room didn't warp the jam so bad the door wouldn't open and close. If you want to leave it as is you could try to wrap the opening for the dead bolt with sheet metal for added strength but the door would be easily kicked in at the jam.
Good Luck
Tom
Statjunk
DIY Senior Member
HJ,
Good eye! I didn't even notice that the stud sitting next to the door was a 2x4.
That would make a good what is wrong with this picture test. LOL
Tom
Mikey
Hansville, Washington
I've had similar problems with prehung doors whose hinges are set such that only one screw can hit the adjoining stud, and even that one only catches about 3/16" of the stud. For a new doorway, I rip a 2x to 4" wide, giving me a jack stud which winds up flush with the drywall on the inside of the door. For an existing doorway, I glue-and-screw 1/2" thick pieces ripped from a 2x4 onto the existing stud at the hinge locations. The doorframe is placed as close to the stud as possible when the door is hung, and the drywall butts against the stud. (In old work, the existing drywall is notched around the pieces.) The case molding covers the edge of the stud or the pieces.
This is not as much work as it seems, and the resulting door installation is very solid. I think the OP could use a similar technique to build out the jamb where the bolt goes through, and strengthen it considerably. Don't know how he might finish it, but there are several options. If that wall is fairly short, just fur out the entire wall that way and sheetrock it; if not, just make the extra woodwork around the door as attractive as possible.
Another door tip - for some reason known only to God and Stanley, the "standard" screws used in most door hinges are #9 screws. Try to find 2 1/2" long #9 brass, Philips-head screws anywhere. However, Grabber makes a #9 yellow zinc, square-drive screw in 2 1/2", 2 3/4", and 3" lengths that make dandy hinge screws (http://grabberman.com). Probably not as much shear strength as a wood screw, but in my experience the screw pulls out of the jamb (or the door) long before the shear strength is tested.
As for the snakes -- be happy they aren't rats. Snakes are your friends.
Chestnuts
DIY Member
More on the back door......
Here is what the previous onwer did to try to stop someone from kicking in the door. A bar with a 3" lag screw. He also placed the metal screen over the window so no one could break the glass, reach in and unlock the door.
Chestnuts
DIY Member
Yes, I knew the obvious answer was to replace the door, I was just not wanting to have to go that far. After removing the old door, I found a rotting 2X4 next to the frame. We cut out the board and installed a new one that had been treated with watersealer. Then we installed a new prehung steel door. It took 3 doors (well, the first was my measuring error, but the second door frame was built wrong), but it is finally installed. Now I can continue the work on this room.
Mikey
It looks like the door isn't parallel to the wall -- the hinge side looks to be set deeper than the striker side. Is this just an optical delusion? (I've got an interior door like that. The walls on either side of the opening weren't in the same plane.)
B2CHR
Central NC
After installing many of them over the years, and I might add in kind of shady neighborhoods, I have found if you take two 2 1/2" screws and counter sink the into the edge of the door jamb about 1/2" above the lockset it "helps" keep the door from being kicked in as easy. Remolded 5 homes in a row on the same street here a year ago and after the first two having the doors kicked in I started doing this and the doors held when they tried it again. One small kick and the jamb splits right at the holes that are bored for the lockset. Putty or patch the screws holes and install you trim with the 1/4" revile and your set to go.
Also I believe I would have used treated 2x4 for the sill plate if that is concrete that it is sitting on.
