Checking your water pressure is an excellent idea. You do not need to call anyone to do this. Just go to any hardware store and purchase a water pressure gauge that attaches to a standard hose bib. This could at your washing machine or any other faucet with hose threads. Then turn the faucet on and read the pressure. If the pressure is much over 60 psi, it is too high and you should have a pressure regulator installed or if one is already in place, reset or replace it as they do sometimes fail. This valve is a bell shaped device usually found very close to where you water supply enters the house. Not part of you present problem but nevertheless important, is a pressure regulator requires a thermal expansion tank to be install also. There have been numerous discussions on this forum regarding these devices and I won't rehash all of that business now. Suffice it to say that excessive pressure can and does harm appliances such as toilets, so this could be a possible cause of your valve failures.
