rmateyko
06-30-2008, 10:01 PM
I am doing a basement reno and need to tuck a p-trap up into the joists. The p-trap comes from a main floor bathroom . I can either drill a hole in the joist just above the hole that is already there from the existing p-trap or route the drain alway from the hole that is there and drill the new hole about 6 inches away from the current hole.
The joist is seven inches deep and I am running 1 1/2 inch plastic drain which means a 2 inch hole. The joists are true 2 inch fir joists - it is an older home.
I am planning on sistering the joist about 3 feet on either side of the hole - which is the best I can do given what is there.
I would prefer to run the drain away from the hole by turning the p-trap parallel to the joist and then doing a 90 degree into the joist which means I would have to follow with another 90 degree to get to the stack. This allows me to position the second hole away from the first. However, I think it may have some plumbing ramifications given I am doing two 90 degree turns - I would use long sweeps.
Otherwise I will have to cut a hole just above the existing hole and likely weaken the joist and am not sure of the structural implications of the combination of sister and joist with two 2 inch holes next to each other in the original joist. Note there would only be one hole in the sister.
I have also thought about routing the p-trap on a 45 but that would mean I have to cut a hole on a 45 and I think that takes more skill than I have - especially through a joist and a sister.
Does it matter that I am doing two 90 degree turns? I have included a diagram of the situation showing two views.
Roman
Roman
