View Full Version : Hints for removing brass hose bib?
SteveW
05-08-2005, 05:07 PM
I could use some hints. I was trying to remove a 3/4" brass hose bib from an irrigation pipe which looked to be 2" galvanized. Although it looked like pipe dope was used, I could not budge the hose bib! Used a standard-size pipe wrench (the flats had been rounded off already -- apparently someone else had trouble getting it off, too!). Put all my weight into it, didn't move a bit. I was afraid I'd break the fitting or pipe (probably an irrational fear, I realize).
Any thoughts/hints? Cheater pipe? Heat?
05-08-2005, 07:11 PM
Without seeing it we cannot tell if there is some reason why your wrench did not unscrew it. But if it is a threaded connection, then a larger wrench or a cheater bar may be all you need.
SteveW
05-10-2005, 04:28 AM
I took another look at it -- actually now looks like there is no pipe dope/Teflon tape on the threads. It is 3/4" threads on the brass hose bib going into a 2" x 2" x 3/4" galvanized tee.
Any other suggestions other than brute force? Does penetrating oil help, like it does with rusted automobile fasteners?
05-10-2005, 05:14 AM
brute force.
SteveW
05-10-2005, 05:21 AM
Got it! Thanks, hj.
Cal
05-11-2005, 01:40 AM
On rare occasion, if you can get the threads to TIGHTEN just a hair it will "crack" the seal and allow you to spin it off.
05-11-2005, 04:48 AM
I don't think I have ever had any thread that it was easier to tighten it a bit, than to unscrew it. But the theory is good.
SteveW
05-11-2005, 03:29 PM
Definitely worth a try! Thanks.
Cal
05-12-2005, 12:53 AM
ANY of us in the buisness know,,,,plumbing is the MOST fickle thing there is.
captwally
05-18-2005, 02:33 AM
Blast the thing with a torch of MAPP gas, not propane. Hold the torch there several minutes while you talk on the phone or whatever.
Ooops, I see you already got it.
SteveW
05-18-2005, 05:53 AM
Actually, the organization that rented me the garden space went ahead and called a plumber, so yes, it did get taken care of. But I really appreciate all the advice and will make good use of these ideas down the road!
Thanks.
