Macman
- Messages
- 102
- Reaction score
- 0
- Points
- 16
I have 15 boxes of 17 inch ceramic tiles sitting in my garage waiting for installation (see post below http://https://terrylove.com/forums/showthread.php?t=21310). These were ordered (as opposed to getting them from available stock) so that they would all come from the same dye lot. The control numbers on all the cases are identical, so I assume this means that they are indeed from the same dye lot. However, 14 of the 15 boxes have a "caliber" number of 5, while one of the boxes has a caliber of 4.
I need to know if this is an issue, and if I should be pressing the supplier regarding this? A Google search doesn't turn up much, except that it has something to do with size. I assume that this is in reference to width, not thickness. If this is true, then those tiles could probably be used along edges where they will be cut to fit anyway?
Comments are appreciated.
