View Full Version : Adjusting Float Ball in Toto Toilet
memphisliza
05-08-2005, 04:04 AM
We have a new Toto toilet, and it continues to run after being flushed. When I look inside the tank, the water is right up to the top of the overflow tube and running down. If I lift up the float ball a little bit, the water stops running and when I put the ball down, it stays off, but the water is right up to the top of the overflow tube. I'm not sure what to adjust, but clearly I need to turn off the tank fill valve sooner. Thanks for any help.
RioHyde
05-08-2005, 05:19 AM
When looking at the top of the fill valve you'll see a screw there....right smack dab on top. Turn it clockwise to decrease the water level in the tank.
good luck
memphisliza
05-08-2005, 10:34 AM
thanks, it was very obvious how to adjust the float until the water level reached the line marked "water fill". Can't believe it was so easy. Thank you for such a quick reply.
