toilet to flush-up
008170
Terry I need a toilet that I can install floor level, but needs to fit into a waste pipe that is 8" above floor level. The floor support beem is sandwiched with a metal plate, so I need to run the toilet drain up and over it to get to the waste pipe. Thanks for your help Jim
Since water does not run up hill on it's own too well, you will need to invest in an ejector pump system. This is a project probably best left to a professional plumber unless you have more plumbing experience and knowledge than your question indicates. I have limited knowledge of these systems myself, but I do know they require a pit, pump, and venting as well as the rest of the plumbing. My best advice to you is to contact a local plumbing contractor and discuss your options.
