How do they add a tap on a gas line?
A friend has an order in with the local natural gas company to run gas from the line at the road to his house (no gas there now - uses oil to heat). He asked, and I didn't know, how they make the connection and the tap. I'm pretty sure that they wouldn't turn the gas off for the whole road as that would mean visting potentially hundreds of houses to ensure pilots, etc. were working once it was turned on again not counting the inconvenience to all of those existing customers.
When they install the gas lines in the first place, do they put a T in and cap it where they think there might eventually need to be service? Or, are they able to add one as needed? If so, how?
Curious minds want to know!
Jim, I'm amazed you ran into a stumper.
I don't know the answer either, so guess we'll wait to see who shows up.
Charlie
I know that they generally don't leave a T anywhere for future consideration unless there already is an applicant for gas at time of installation. They do however have a saddle, similar to what I've seen installed on some water mains that create a seal, and then pierce the line. Depends on what the line is constructed of. Not exactly my expertise, but I do work in underground utility construction, mostly in new pipeline crossing installments
steve
They do it using a technique called "hot tapping". The equipment involved varies by piping material but basically you attach new fitting and valve, attach the hot tapping machine (think drill) to the valve, perform the tap, close the valve, and remove hot tapping machine. The bit is made to retain the plug, called a coupon, you just drilled out. I'm sure there are otherways but that's the one I'm familiar with.
-Sam
Thanks Sam
that explains it a little better that I could. I've seen it, but never done it and you are right, small plastic mains are a pretty quick exercise, but I'm not sure exactly what they do on old steel mains
steve
I had seen a similar thing for a water line (don't remember the name now), but wasn't sure if it would apply to gas.
Thanks Sam
steve
Use a bigger drill :D Check out the Furmanite website; they'll pretty much punch a hole in any pipe, anywhere.
Thanks Sam
steve
When they moved my gas meter (and did some other work in the area) they welded the new valves on with an arc welder and then did the drill threw the valve. This is probably 30 to 40 year old steel pipe under the street. And yes they welded with the gas still on the the street.:eek:
Gas can't burn or explode if there's no oxygen...just don't try this yourself!
gas
I was working on a two building apartment complex years ago. The gas line between the two buildings had rusted out, so after a lot of discussion convincing the gas company that they COULD install a second meter at the affected building they came out on a Sunday and proceed to make the connection. In the process of connecting the new line, however the mechanic shut off the supply to the working meter. His foreman asked him, "Do you know what you just did?" When the guy said, "No," the foreman told him that he had just turned off all the stoves in the building, and that the plumber, ME, now had to pressure test the entire building before they could restore gas to the meter. They got one of the most creative gas tests I have ever done, but as long as they were satisfied that was all that counted. A hardnosed supervisor might have required a city permit and inspection before restoring service even though it was their fault and everything was working perfectly before that.
