View Full Version : P Trap question
justme
05-03-2005, 07:10 PM
I am in the process of installing a bar sink outside on my lanai. I hae puntchured the wall for the drain that will connect to my kitchen drain. My question is my drain pipe is higher then my sink drain. Will that cause a draning problem? Thanks for the advcie
NO way to tell without seeing how you make the connection.
captwally
05-03-2005, 08:46 PM
Just remember that water seeks it's own level
justme
05-04-2005, 04:43 PM
To ask a silly question? My drain pipe (exit) is higher the the bottom of the sink. Will that creat a problem for draining?
The water in the sink that is higher than the drain will empty normally. But once the level gets even with the drain in the wall it will stop draining and the water level will stay at that point forever.
