molliemcguire
- Messages
- 3
- Reaction score
- 0
- Points
- 0
I woke up this morning to find I had no water in my pipes. I can turn the pump breakers on and the pump runs, but again, no water. I have 26psi in the pressure tank. I should also add I have a sand point and I can see water in the casing, so my fear of no water was unfounded.
I do have much iron and rarely some flakes in the water, so at this point I am assuming my pump impellers are shot, since the pump runs when the breaker is on? It was quite warm in the pump house when I climbed down into it and the pump was very hot. Am I safe to assume the pump ran itself to this temp and I need a new jet pump? I can do this repair myself I am 99% certain. but I do need advice on any other things to look at before I 'convince' myself it's the pump.
Also, a friend of mine gave me advice to remove the cover to the relays and push down on them with a screwdriver and see if they kick the pump on or not. What will this tell me and will i get shocked? thank you for your time
