Well pressure drops
Mad Plumber
Mad Skills
I have a problem with my pressure from my well. The well is just for the sprinkler system. It start out really strong at 30 and about four minutes it drops down to 20. This just does not seem to be enough pressure. Is there a way to get more pressure or to keep it at 30 ? Thanks. Hope you can help ME!
Sue333
The pump is what keeps it at 30 but, it can't do that unless there is enough water to pump. It sounds like you are pumping all the water out of the well. Your well screen may be plugged. We need a little more info on the pump and well such as water level before and after pumping.
Well Pressure
Thanks for answering me. Hope this info helps.
It is a Goulps Pump Itt, 1 hp Rpm 3450
Pressure before pump starts is 57 Drops to 30 and then about 4 minutes later it drops to 20. Hope that answers your questions. thanks Sue
Pressure Problems
Well you got me there. The pump is above ground, but that's all I know. How do I go about to find out what the water levels are???? Thanks For trying to help me!
Pressure Problems
All I see is two. It kind of looks like this n does just sticking out of the ground.
