Kitchen Sink -- disposal hookup, drain miscalculation
RemodelBob
Washington
When I roughed in my kitchen, I placed my 2" drain stub out where I thought would be close to the edge of the cabinet making it easy to install my p-trap and disposal.
As it turns out, the wife wants the disposal on the left side, which is just about right in front of my stub out. If I moved it to the right basin it would be a no brainer, but I would never be able to change it up.
So I am going to rig it to fit in the left side.
Here is what I have, let me know if this is legit or crazy.
2" stub out
2" 90 (short on the horizontal--wrong I know, but well oversized--just not enough room for a long sweep)
2"-1.5" bushing
1.5" Y to street 45 to disposal p-trap
1.5" Y to street 45 to right basin p-trap
1.5" 90 to stub to studor vent (AAV)
The pictures are of the problem and the un-glued setup. The san-t you see with pipe is just there to hold it up. I am going to strap it to the back wall as cleanly as possible.
Let me know what you think...in the meantime I will be chipping away at the leftover plywood the counter buys left in the way of my faucet hookups...
drain
Of all the possible ways you could do it, and we would have to be there to determine the best one, you have chosen the worst. It would never pass ANY inspection, and will have many functional problems if you do it that way. Your first mistake may have been using 2" pipe.
It looks like you are working way to hard to hook up a drain. It looks pretty though.
I'd hook up the faucet before I put all that stuff in the way...
Have you confirmed that AAV is allowed? Most places, the fact that it may be difficult to get to a real vent does not mean it is impossible, and the inspectors do not allow it.
Assuming the AAV is allowed, are you allowed to come of the horizontal like that? Also, does anyone allow for two traps on one arm like that?
-Sam
AAVs are allowed--it is a little tough to put a vent line in after the sheetrock and cabinets are installed.
HJ, how would you hook it up? This was my mock up and I was looking for advice because I didn't like how complicated it came out.
I could have simplified down to one Y and have both sinks share one p-trap, but those dual sink diverters look to constrict the flow a lot.
You should have the vent before the p-trap, if you use an AAV, then it would be on a fitting before the trap. In the drawing above, the pipe going up is the vent,
With an AAV, the pipe would be cut shorter, and the AAV installed. (with access for air and replacement)
when you say "before the p-trap" do you mean between the p-trap and the wall?
I think that is what I have. I just put the AAV off to the far right because I wanted to get it as high as possible (with room to remove and replace if needed).
I would hook it up just like your drawing, but the drain stub out is directly behind the disposal, which is why I am here looking for layout advice.
Thanks
Rob
Right now you have vent, trap, trap, drain. You want trap, vent, drain.
Like HJ said, using 2" pipe in the cabinet isn't helping matters.
What is the dimension between the disposer housing and the back of the cabinet?
Is the dishwasher to the left or right of the sink?
-Sam
What is the problem with 2"? Everything I have read says that oversize pipe is better. Some places have even said that oversized pipe can eliminate the need for a vent. Since there was no practical way install a vent, I opted for oversize pipe and an AAV. I could understand smaller pipe being a problem, but why would larger pipe be a problem?
I don't have an exact measurement right now, but the 2" 90 is about 1" away from disposal housing. My guess is a 2" 90 is about 4". So I am guessing 5" from the back of the cabinet.
Dishwasher is to left of cabinet.
So what you are saying is pull the vent off the Y on the left and use one of those constricting double sink hookups into one p-trap and dump that somewhere further to the right?
drains
You have been reading the wrong materials. Because of flow velocities and self scouring properties, larger drain lines are not always better. But in your case 2" does not give any advantages and takes up more space. The problem with your mock up is that both drains connect to "S" traps, and the AAV does absolutely nothing to improve them. I might place an elbow behind the disposer, then a 1/8 or 1/16 elbow facing towards the right hand sink. Then use a conventional disposer/continuous waste configuration with the trap connecting to the drain pipe, after installing a 2x1 1/2 reducer and then a trap connector.
Thank you. I will mock that up tonight.
based on your feedback I came up with this mockup. let me know what you think.
2" 90
2" - 1.5" bushing
1.5" section of pipe
1.5" Y off to AAV
1.5" 90 to trap adapter (currently have a street 90, but thinking about using a long sweep)
The first picture shows what the ABS looks like.
The second shows the pvc slip joint p-trap setup.
I am not in love with that diverter, but if that is the way to do it, then so be it.
Thanks
drain
Scrap the disposer's outlet elbow. You should have gotten a disposer kit continuous waste with a straight flanged tailpiece, (instead of the elbow one you have which is to connect two sinks with strainers rather than one of them being a disposer), which connects directly to the disposer and goes directly to the tee, rather than making two 90s before going horizontal.
