Hi
I'm changing my countertop and other things in the kitchen so wanted to add some shutoff valves under the sink so I could have water in the rest of the house while I did the work.
It seemed like a simple job...unscrew hoses under the sink and screw in new valves. But for some reason, I have a "slow" leak where both valves are screwed in the pipes/hoses. Like a drop of water every couple of minutes.
I was told at hardware store not to put teflon tape because thread is small so it's not needed. Make sense?
What are the possible causes?
Over tight? If yes, new hardware is needed or just untight a little?
Old hoses bad where they screw in the valves?
Anything else?
Thanks for advice.
Before I touched anything...
After with leak...
Anything else?
Thanks for advice.
After with leak...
